I have x2 2TB drives that I want to make a single Raid0 logical drive. The error I'm getting doesn't make any sense. Can someone explain what I'm missing here?
I use
lsblk -o name,mountpoint,size,uuid,fstype,model,serial
I see both devices are mounted, and the size is the same (953.4G*). I know because when I installed them, I had different fstypes on them, so I changed them both to ext4, then used dd to make them identical in terms of partitioning.
*Yes, I know this partition isn't using the full size of this drive right now.
I'm trying to use btrfs,
mkfs.btrfs -f -d raid0 -m raid0 zdata1 zdata2
but I get the error
ERROR: 'zdata1' is too small to make a usable filesystem
ERROR: minimum size for each btrfs is 131072000
EEM23
I've tested using loop devices:
Create images:
dd if=/dev/zero of=test1 bs=1 count=1 seek=4294967295
dd if=/dev/zero of=test2 bs=1 count=1 seek=4294969343
Add them as loop devices:
losetup -f test1
losetup -f test2
Check for the loop devices used:
losetup | grep test
/dev/loop8    0      0     1  0 /home/davod/test1     0     512
/dev/loop9    0      0     1  0 /home/davod/test2     0     512
Then, create the BTRFS pool:
mkfs.btrfs -f /dev/loop8 /dev/loop9
It worked for me.
If you don't have important data on the disks, just use ZFS, using the entries devices, and use a separated device (a SSD) for boot (EFI partition if the machine has it, and ext4 for GRUB), and empty partitions for L2ARC and ZIL).
