I am very surprise to not found the answer to my question.. I searched but can't reached the answer, so if it exist on the forum just tell me... (i am not used to this kind of research..)
I have win 10, I shrink my ssd then prepared a partition about 200gb for ubuntu, I booted on an usb drive, my pc is a lenovo t440p, processor i5, 16gb ram, and I tried to follow install tutos (like this one https://techfoss.net/install-ubuntu-along-with-windows-in-dual-boot/ )
The tuto asks to build: / (root) – 10 GB SWAP – 4GB /home – Remaining (here 86GB)
But in reality I can build the "/ (root)" and after i am stuck because the freespace is now called: "unusable memory".
I learned on internet that windows 10 accept only 4 partitions and use already 3 of them !! but Ubuntu needs 3 partitions too !!! And now I don't know how to create my 3 needed additional partition for ubuntu install as the max available is 4..
Is there someone that know a similar post I missed, or have the answer..
Thanks, Louis
I found how to do, thanks to mook765 and oldfred comments. I did not know the MBR/UEFI differences.
SOLUTION: I transform my windows 10 disk in GPT using the command line MBR2GPT (well described here: https://www.windowscentral.com/how-convert-mbr-disk-gpt-move-bios-uefi-windows-10 ), Then I was able to have the number of partition I wanted. This procedure does not erase any windows or personal data and it takes not more than 3 minutes total.
to decide the partitions to do this post was very interesting: How large should I make root, home, and swap partitions?
Make the non root files first with the setting of last, then add the /root to the beginning. This worked for me. It took me a while to figure it out since no one posted this when I did my own digging.
S.H.
One of the solutions - which you already did - is to change MBR partitioning to GPT.
But even if you stay with MBR, you can have more than 4 partitions. MBR allows for maximum 4 primary or extended partitions (there can be at most one extended partition). The extended partition is the way to overcome the 4 partitions limit: The extended partition is a "container" that can hold more partitions. So you can have for example 3 primary and one extended partition and have more partitions (they are called logical partitions) inside the extended partition. Logical partitions are exactly as good as primary partitions to install the system on.
raj
  • 11,409
