Since the official chromium-browser switched to relying on the Snap-packaged variety, the browser gets "Permission Denied" when attempting to read any directory mounted after boot. For example, attempting to read the contents of a Kubuntu Live CD gives an error like:
Could not read the contents of kubuntu-20.04-live
Error opening directory '/media/travis/kubuntu-20.04-live': Permission denied
This happens for any volume which is not mounted at boot time (I haven't tested every possibility here, but seems to hold true). To grab a few examples, here's a clip from mount:
$> mount
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p2 on / type ext4 (rw,relatime,errors=remount-ro)
/dev/sdc2 on /media/travis/kubuntu-20.04-live type iso9660 (ro,nosuid,nodev,relatime,nojoliet,check=s,map=n,blocksize=2048,uid=1000,gid=1000,dmode=500,fmode=400,uhelper=udisks2)
media-server:/volumes/shared on /mnt/media-shared type nfs4 (rw,nosuid,nodev,noexec,noatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.1.109,local_lock=none,addr=192.168.1.23,user=travis)
/proc: OK/: OK/home/travis: OK/media/travis/kubuntu-20.04-live: can not read/mnt/media-shared: can not read
I'm guessing this has to do with mount namespaces, so here's lsns:
$> lsns --type mnt
NS TYPE NPROCS PID USER COMMAND
4026531840 mnt 77 1616 travis /lib/systemd/systemd --user
4026533212 mnt 13 9697 travis /snap/chromium/1043/usr/lib/chromium-browser/chrome --no-default-browser-check --no-first-run --password-store
If I use nsenter to read from the volumes as I think Chromium should see it, things appear to work just fine:
$> sudo nsenter --target 9697 --mount -- ls -al /media/travis
total 12
drwxr-x---+ 3 root root 4096 Mar 22 09:24 .
drwxr-xr-x 3 root root 4096 Apr 16 2019 ..
dr-xr-xr-x 9 travis travis 4096 Mar 16 2020 kubuntu-20.04-live
$> sudo nsenter --target 9697 --mount -- ls -al /media/travis/kubuntu-20.04-live
total 964
dr-xr-xr-x 9 travis travis 4096 Mar 16 2020 .
drwxr-x---+ 3 root root 4096 Mar 22 09:24 ..
-r--r--r-- 1 travis travis 351 Mar 15 2020 .treeinfo
The browser, however, stubbornly refuses to list the contents of these directories if I attempt to choose a download location or pick a file to upload. What gives?
As a point of clarification: I am not installing Chromium through Snap directly, but using the official Ubuntu chromium-browser package installed with apt install chromium-browswer. The /usr/bin/chromium-browser found there is just a shell script that calls /snap/bin/chromium. The package has a preinst script that calls snap install chromium, so you are downloading Chromium from Snap even when you don't want to.
