I am using ubuntu 11.10 with cairo dock in an acer aspire with core i3 2nd gen processor with intel graphics.
I downloaded a program gingkocad as a tar file, opened the package with archive manager and created a folder for the package contents.
To run the program I need to click the executable to run in terminal.
Is there a way to create a shortcut to run the executable from an icon in cairo dock ?
Please help.
RolandiXor
  • 51,797
ragv
Just drag the executable onto Cairo Dock. But don't drag it onto an already placed icon. Put it in between two icons. That's it.
RolandiXor
  • 51,797
Ashu
  • 9,642
The shortcut-icon in cairo-dock are called launchers. Cairo-dock supports drag and drop.
  1. Try dragging and dropping the application executable into any space between icons already on dock. This works for a good number of applications.
  2. If that fails, try this:
    • right-click on the dock, then select add>custom-launcher.
    • A new window will appear. Fill the field Launcher name with the name of your application, and 'command to run on click' with the full path to executable file.
    • Then click apply at the bottom right corner, and you should be done.
This method, however, does not provide some features such as having quicklists. To achieve quicklists:
For advanced users
  • Open a editor of your choice. ( Novice users can search for 'text editor' in dash and use gedit. - gedit is the text editor that appears in Dash)
  • Make a .desktop file with the required quick-lists.
    This can be used as a reference.
    And here's a nice link explaning all the options possible in a .desktop file.
    (Note: X-* options are excluded here, as they are considered non-standard)
  • Save the file as <your application name>.desktop
  • Drag and drop this to cairo-dock. (on space between icons)
This will always work, provided the .desktop file is made correctly.
Mahesh
  • 13,026
