I try to reinstall ansible in my ubuntu18.04 laptop.
I've got this dependencies problem :
$ LANG=C sudo apt-get install ansible
Reading package lists... Done
Building dependency tree
 ansible : Depends: python-httplib2 but it is not going to be installed
           Recommends: python-winrm (>= 0.1.1) but it is not installable
So when I try this packet :
$ LANG=C sudo apt-get install python-httplib2
 python-httplib2 : Depends: python:any (< 2.8)
                   Depends: python:any (>= 2.7.5-5~)
                   Depends: ca-certificates but it is not going to be installed
Of course, python (2.7 & 3.6) and ca-certificates are well installed and functional.
When I try to install this packet via synaptic, Synaptic propose me to remove almost all the ubuntu packets :/
If I try to install manually the .deb from https://packages.ubuntu.com/bionic/libs/python-httplib2
I've got this :
$  LANG=C sudo dpkg -i Téléchargements/python-httplib2_0.9.2+dfsg-1_all.deb
Selecting previously unselected package python-httplib2.
(Reading database ... 236487 files and directories currently installed.)
Preparing to unpack .../python-httplib2_0.9.2+dfsg-1_all.deb ...
Unpacking python-httplib2 (0.9.2+dfsg-1) ...
dpkg: dependency problems prevent configuration of python-httplib2:
 libssl1.1:amd64 (1.1.1-1ubuntu2.1~18.04.5) breaks python-httplib2 (<= 0.9.2+dfsg-1) and is installed.
  Version of python-httplib2 to be configured is 0.9.2+dfsg-1.
dpkg: error processing package python-httplib2 (--install):
 dependency problems - leaving unconfigured
 python-httplib2
this is certainly why, by removing libssl1.1:amd64 , synaptic want to remove all ubuntu...
I verify, all my packets are OK
- sudo apt install -f - sudo apt --fix-broken install - sudo apt install --reinstall libssl1.1 python-httplib2 - ... All the magic commands i usualy try to resolv this situation.
I find in /var/log/apt/* that 9 month a go, ansible was removed (with this famous python-httplib2 ) (I usualy don't use ansible from my laptop...):
Start-Date: 2019-09-02  16:40:54
Commandline: apt install libio-socket-ssl-perl libnet-ssleay-perl libpython3.6 libpython3.6-dev libpython3.6-minimal libpython3.6-stdlib libssl-dev libssl1.1 openssl python-cryptography python3-cryptography python3.6 python3.6-dev python3.6-minimal
Requested-By: cesnault (1000)
Upgrade: libpython3.6-minimal:amd64 (3.6.5-3, 3.6.8-1~18.04.1), libnet-ssleay-perl:amd64 (1.84-1build1, 1.84-1ubuntu0.2), openssl:amd64 (1.1.0g-2ubuntu4.3, 1.1.1-1ubuntu2.1~18.04.4), libpython3.6-dev:amd64 (3.6.5-3, 3.6.8-1~18.04.1), libpython3.6-stdlib:amd64 (3.6.5-3, 3.6.8-1~18.04.1), libpython3.6:amd64 (3.6.5-3, 3.6.8-1~18.04.1), python3.6:amd64 (3.6.5-3, 3.6.8-1~18.04.1), libio-socket-ssl-perl:amd64 (2.056-1, 2.060-3~ubuntu18.04.1), python3.6-minimal:amd64 (3.6.5-3, 3.6.8-1~18.04.1), python-cryptography:amd64 (2.1.4-1ubuntu1.2, 2.1.4-1ubuntu1.3), python3-cryptography:amd64 (2.1.4-1ubuntu1.2, 2.1.4-1ubuntu1.3), libssl-dev:amd64 (1.1.0g-2ubuntu4.3, 1.1.1-1ubuntu2.1~18.04.4), libssl1.1:amd64 (1.1.0g-2ubuntu4.3, 1.1.1-1ubuntu2.1~18.04.4), python3.6-dev:amd64 (3.6.5-3, 3.6.8-1~18.04.1)
Remove: ansible:amd64 (2.5.1+dfsg-1ubuntu0.1), python-httplib2:amd64 (0.9.2+dfsg-1)
End-Date: 2019-09-02  16:42:37
but I can't figure out why I install this lib for ?
Any idea will be welcome please
Thank you.
Cédric
