I'm trying to configure my Raspberry Pi 4B running Ubuntu 18.04 with a static IP address (to then configure a DHCP server) and use the WiFi for internet traffic (routing any clients connecting to the DHCP through to the WiFi connection) but I cannot define a static IP address for the LAN, using netplan I have the config: `network: #LAN connection for ipv4 DHCP server version: 2 renderer: networkd ethernets: eth0 addresses: - 10.0.0.1/24 gateway4: 10.0.0.1 nameservers: addresses: [8.8.8.8, 4.4.4.4.4]
    # LAN connection ipv6 - using for DHCP Server
    version: 2
    renderer: networkd
    ethernets:
            eth0:
    addresses:
            - 2001:1::1/64
    gateway6: 2001:1::2
    nameservers:
            addresses: [8.8.8.8, 4.4.4.4]
    # wifi connection
    wifis:
            wlan0
    dhcp4: true
    dhcp6: true
    access-points:
            "SSID-name"
    password: "WiFi Password"
I keep getting indentation errors when I try to apply the plan. The indentation is that which is created when I manually type in the details.
sudo netplan -debug generate
/etc/netplan/50-cloud-init.yaml:11:17: Error in network definition: expected mapping (check indentation)
                eth0
