I'm running on a Ubuntu 10.04, and installed an 8.04 version in a directory /stuff/hardy
sudo debootstrap --variant buildd --arch i386 hardy /stuff/hardy http://archive.ubuntu.com/ubuntu
What I want to do is to get a working environment isolated from my linux machine (without installing into another partition).
My problem is, that when I chroot into it (sudo chroot /stuff/hardy) I notice that I have nothing in /proc or no network configuration. Also, if I try to go back to my home directory (inside hardy, not 10.4),
hardy# cd I get a /home/myuser No such file or directory
Is there an (hopefully easy) way to get an ubuntu install using debootstrap with no a lot of extra work ?
Thanks in advance
Kees Cook
  • 17,823
Tom
  • 253
You can use schroot instead of chroot, it will take care of setting up /proc, /etc and cross mount your home. You can use the following script which helps to build/setup a schroot: http://bazaar.launchpad.net/~debfactory-devs/debfactory/devel/download/head%3A/schroot_build.py-20090314124651-txt9bwioeycax53m-1/build_schroot.py
João Pinto
  • 17,323
Yes, schroot is the way to go if you want to set up a more complete environment in your chroot. I recommend installing ubuntu-dev-tools and using mk-sbuild which will do everything for you automatically.
http://manpages.ubuntu.com/manpages/lucid/en/man1/mk-sbuild.1.html
Kees Cook
  • 17,823
