After doing this on Ubuntu 16.04.6 LTS:
root@ubuntu:/home/dirk# sudo a2enmod php7.2
root@ubuntu:/home/dirk# systemctl restart apache2
Joomla 3.9.16 (with maximum error log) shows at the browser then:
Warning: session_start(): Failed to read session data: user (path: /var/lib/php/sessions) in /var/www/so-geht-es/libraries/joomla/session/handler/native.php on line 260
Error: Failed to start application: Failed to start the session
What to change PHP because of this message within the backend of Joomla:
Error
We have detected that your server is using PHP 7.1.33-12+ubuntu16.04.1+deb.sury.org+1 which is obsolete and no longer receives official security updates by its developers. The Joomla! Project recommends upgrading your site to PHP 7.2 or later which will receive security updates at least until 2020-11-30. Please ask your host to make PHP 7.2 or a later version the default version for your site. If your host is already PHP 7.2 ready please enable PHP 7.2 on your site's root and 'administrator' directories – typically you can do this yourself through a tool in your hosting control panel, but it's best to ask your host if you are unsure."
But with PHP 7.2 I get the error mentioned.
How am I able to figure out what causes this issue?
