OS: Ubuntu 19.10
I'm playing around with Apache so I can learn how to configure it, so I installed it via apt-get and took a look at the config directories.
I also am vaguely aware that with Apache on macOS all the default addresses end with a .local TLD, so I tried navigating to my box in a web browser using its hostname and the .local TLD, i.e. http://mybox.local/. And it worked, I see the apache default page.
But looking at the apache config files and virtual host config, nowhere is this server name defined. So I looked up as best I could how this extension is configured, and I found this page saying the avahi-daemon is responsible and how to work the config.
I changed the server settings to a different TLD, eg '.blarg' and I restarted the avahi service - which doesn't work, even with an Apache service reload, yet somehow the .local TLD still works, even after a reboot.
This leads me to believe either I'm restarting the wrong service, or avahi isn't responsible for the .local extension. Anyone care to point me in the right direction?
Dan
  • 14,180
There's no magic going on, really.
What you have is a fresh installation to Apache. So, by default, any request on port 80 to your machine will show you the default apache welcome page.
For example, the following would work as well:
  • http://127.0.0.1/
  • http://localhost/
If you need to add another domain, you need to point that domain to your machine. The simplest way to do that on a development machine is to edit the /etc/hosts file and a new entry.
Open the file with an editor and add the following line (change mybox.something to whatever you want):
127.0.0.1   mybox.something
After you do that, just open http://mybox.something in your browser and it should work.
Dan
  • 14,180
