Whenever I try to install something, I get the same error:
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/repo.mongodb.org_apt_ubuntu_dists_bionic_mongodb-org_4.0_multiverse_binary-amd64_Packages
E: The package lists or status file could not be parsed or opened.
I've tried to do the following:
sudo rm -r /var/lib/apt/lists/*
sudo apt-get clean && sudo apt-get update
which was the solution proposed in many places, but it didn't work.
Does anybody know how to fix this?
zx485
  • 2,865
Remove mongo lists in:
/etc/apt/sources.list.d
then:
sudo rm -vf /var/lib/apt/lists/*
sudo apt-get update
hloop
  • 71
I seemed to have to do the following, which is a combination of several posts I've seen that didn't work for me.
1: Remove all mongo lists in /etc/apt/sources.list.d
cd /etc/apt/sources.list.d && sudo rm -rf mongo*
2: Remove everything in /var/lib/apt/lists/
sudo rm -rvf /var/lib/apt/lists/*
3: Clean
sudo apt clean
4: Update
sudo apt update
Same problem Ubuntu 18.04.4 LTS
Solution: Use the following commands in this order
Move or remove mongodb-org-4.0.list, here I moved it with mv, use rm insteand to delete.
sudo mv mongodb-org-4.0.list /home/
(Remember to change the directory, provide where you want to put it so that you can still reuse it if things go wrong)
remove all lists
regenerate them
sudo apt-get update
Now you can use again Software Updater.
Onyr
  • 163
Remove the problematic repositories, then try removing the MergeList, and then regenerate it:
sudo apt-get update
Farzin
  • 101
