I have login problem of this kind:
A start job is running for Hold until boot process finishes up (Xmin Xs/no limit)
Do when I press Alt+Shift+F2, so it going to login page and the problem is that I can not change language from Persian to English to insert my user and pass.
I already I changing the language at Ubuntu by pressing the Ctrl+Shift+Alt, but it doesn't work here.
So how can I change the language in this mode?
Update: I have this problem in advance boot option (safe mode), grub ...
I also tried to switch language by holding  (if I remember correctly) "the Alt + 122 at numpad" to type English yes at dpkg repair option.
Gryu
  • 8,002
  • 37
  • 53
Soheil Paper
  • 1,429
It seems you have configured your system locale incorrectly.
Using the next command we could get list of available locales:
locale -a
In my case I have:
C
C.UTF-8
en_AG
en_AG.utf8
en_AU.utf8
en_BW.utf8
en_CA.utf8
en_DK.utf8
en_GB.utf8
en_HK.utf8
en_IE.utf8
en_IL
en_IL.utf8
en_IN
en_IN.utf8
en_NG
en_NG.utf8
en_NZ.utf8
en_PH.utf8
en_SG.utf8
en_US.utf8
en_ZA.utf8
en_ZM
en_ZM.utf8
en_ZW.utf8
POSIX
uk_UA.utf8
To get your current locales configuration run locale:
LANG=en_US.UTF-8
LANGUAGE=en_US
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC=uk_UA.UTF-8
LC_TIME=uk_UA.UTF-8
LC_COLLATE="en_US.UTF-8"
LC_MONETARY=uk_UA.UTF-8
LC_MESSAGES="en_US.UTF-8"
LC_PAPER=uk_UA.UTF-8
LC_NAME=uk_UA.UTF-8
LC_ADDRESS=uk_UA.UTF-8
LC_TELEPHONE=uk_UA.UTF-8
LC_MEASUREMENT=uk_UA.UTF-8
LC_IDENTIFICATION=uk_UA.UTF-8
LC_ALL=
Login as root in your gui terminal, where you could change to English and do:
update-locale LC_ALL=en_US.UTF-8 && . /etc/default/locale
Make sure, you have us the first keyboard layout in /etc/default/keyboard
$ cat /etc/default/keyboard
XKBLAYOUT=us,ua,ru
XKBVARIANT=,winkeys,
BACKSPACE=guess
If us not the first keyboard layout, make it the first and execute:
. /etc/default/keyboard
Also, try update-grub2 and update-initramfs -u after previous commands using.
If you could not get into your system because of wrong locales configuration, then
  • boot from Live CD (Try without installing option in Ubuntu installation image)
  • identify your root partition by sudo fdisk -l
  • mount your root partition in read/write mode
  • configure /etc/default/keyboard file as said previously
  • add into /etc/bash.bashrc the next at the end:
    export LC_ALL= "en_US.UTF-8"
    export LANG = "en_US.UTF-8"
    export LANGUAGE = "en_US.UTF-8"
  • try to boot into your system
Gryu
  • 8,002
  • 37
  • 53
The stupid way of solving it that helped me (thanks Gryu):
  1. Login to tty using Alt + numpad code ([A-Z] is 65 to 90, and [a-z] is 97 to 122)
  2. The same way type sudo nano /etc/default/keyboard (code blocks below are numpad code sequences):
    115 117 100 111 (spacebar) 110 97 110 111 (spacebar)
    47 101 (tab) 100 101 102 97 (tab) 107 101 (tab) (enter)
  3. Using arrows, navigate to XKBLAYOUT line and add "us," (117 115 44) after =
  4. Quit nano and save file: 024 121 (enter)
  5. Reboot: 114 101 98 111 111 116 (enter)
May be helpful for someone :)
