im currently setting up my home network infrastructure. Because i have multiple usages and only a single server, i installed proxmox as host system and created a pfsense based VM to use as firewall. The ethernet card is forwarded into the firewall vm, so the setup works when using cable. The next goal was to add wifi to the setup. So i aquired an Asus PCE-AX3000. Sadly the underlying bsd does not support the card, so i created another VM using Ubuntu 19.10 and forwarded the wifi card to that vm. Firstly i want to mention that the card is properly found and loaded by the vm:
01:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
Subsystem: Intel Corporation Device 0084
Physical Slot: 0
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at c1800000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [14c] Latency Tolerance Reporting
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
The main idea is to simply bridge the wifi card with the virtual interface on the vm, which is "plugged" into another proxmox host-bridge, containing the wifi VM and the firewall VM, so i can basicaly whitelist devices in my firewall, as all trafic is handled by the firewall anyway, plus i have a dedicated virtual interface for managing whatever is connected via wifi.
That bridges also completely work. The wifi vm itself uses netplan, so i configured netplan like this:
# This file describes the network interfaces available on your system
# For more information, see netplan(5).
network:
version: 2
renderer: NetworkManager
ethernets:
ens18:
dhcp4: yes
dhcp6: yes
ens19:
dhcp4: yes
dhcp6: yes
wifis:
wlp1s0:
access-points:
Eiveo:
mode: ap
password: ...
bridges:
br0:
interfaces: [ens19, wlp1s0]
dhcp4: yes
dhcp6: yes
Theoretically everything should work, but while the wifi network is found on all devices (phones, tv, pcs, notebooks, ...) Not a single device is able to connect. On the vm i cant manage to find any proper log with some useful information whenever a client connects. What i can find however is this line upon doing a netplan generate and apply:
... wifi NetworkManager[2754]: <info> [...] policy: auto-activating connection 'netplan-wlp1s0-Eiveo' (da5e14bf-7c9b-3545-942c-056eb2fd009b)
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): Activation: starting connection 'netplan-wlp1s0-Eiveo' (da5e14bf-7c9b-3545-942c-056eb2fd009b)
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): Activation: (wifi) access point 'netplan-wlp1s0-Eiveo' has security, but secrets are required.
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): Activation: (wifi) connection 'netplan-wlp1s0-Eiveo' has security, and secrets exist. No new secrets needed.
... wifi NetworkManager[2754]: <info> [...] Config: added 'ssid' value 'Eiveo'
... wifi NetworkManager[2754]: <info> [...] Config: added 'mode' value '2'
... wifi NetworkManager[2754]: <info> [...] Config: added 'frequency' value '2412'
... wifi NetworkManager[2754]: <info> [...] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
... wifi NetworkManager[2754]: <info> [...] Config: added 'psk' value '<hidden>'
... wifi wpa_supplicant[1396]: Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
... wifi wpa_supplicant[1396]: Using interface wlp1s0 with hwaddr 50:eb:71:f9:28:fb and ssid "Eiveo"
... wifi wpa_supplicant[1396]: wlp1s0: interface state UNINITIALIZED->ENABLED
... wifi wpa_supplicant[1396]: wlp1s0: AP-ENABLED
... wifi wpa_supplicant[1396]: wlp1s0: CTRL-EVENT-CONNECTED - Connection to 50:eb:71:f9:28:fb completed [id=0 id_str=]
... wifi kernel: [ 2877.598828] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): supplicant interface state: ready -> completed
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Started Wi-Fi Hotspot "Eiveo"
... wifi NetworkManager[2754]: <info> [...] device (p2p-dev-wlp1s0): supplicant management interface state: ready -> completed
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
... wifi NetworkManager[2754]: <info> [...] device (br0): attached bridge port wlp1s0
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): Activation: connection 'netplan-wlp1s0-Eiveo' enslaved, continuing activation
... wifi NetworkManager[2754]: <info> [...] device (br0): IPv4 config waiting until carrier is on
... wifi NetworkManager[2754]: <info> [...] device (br0): IPv6 config waiting until carrier is on
... wifi NetworkManager[2754]: <info> [...] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Also the key_mgmt value using wpa_cli -i wlp1s0 status seems pretty weird:
bssid=50:eb:71:f9:28:fb
freq=2412
ssid=Eiveo
id=0
mode=AP
pairwise_cipher=CCMP+TKIP
group_cipher=TKIP
key_mgmt=UNKNOWN
wpa_state=COMPLETED
p2p_device_address=50:eb:71:f9:28:fc
address=50:eb:71:f9:28:fb
uuid=2603753d-14b3-5c52-a2a5-6e84b168c25c
I have no idea whats cause the problem, nor how to debug that. As the card generally works, and the whole bridge setup is tested, and the wifi vm itself apears properly in the firewalls dhcp client list, i expect the problem to be specific to the way netplan configures the wifi setup, but as i have literaly no idea where the problem lies, im asking here if anyone might be able to help me out :) Side note: Buying a wifi AP and attaching it via cable is not the desired option!
Thank you very much for assisting me!
