I have a desktop running Ubuntu 19.10 LTS with a GeForce GTX 970. I have two Dell monitors U2515H and a U2713HM, the 27" is setup as primary monitor.
The connection is PC->U2515H->U2713HM, with DP1.2 enabled on the 25"
Previously, I had issues where my secondary display would go into sleep mode, but following this answer fixed my issues.
After upgrading to the newest nvidia driver(440) I am now facing the same issues. The secondary monitor always go into sleep-mode. If I change which monitor is the primary, the secondary is always the one to be stuck in sleep-mode.
I have tried using xrandr as described in this answer, but to no avail. I have not been able to find any other useful suggestions.
Ubuntu: 19.10 LTS
Kernel: 5.5.9
CPU: AMD Ryzen 5 2600
GPU: GeForce GTX 970, nvidia driver 440.64
Leu's solution works like a charm, but for those who do not have a "xorg.conf" in above location (/etc/X11/xorg.conf) - there is simple option to generate one based on your current configuration.
Simply open
"NVIDIA X Server Settings" -> "X Server Display Configuration" -> "Save to X Configuration File"
(bottom right button).
kanehekili
  • 7,426
matty-matt
  • 31
Try this:
In your X-configuration file (should be /etc/X11/xorg.conf) add a Device-Option "HardDPMS", set to "false".
In my case, the Device-Section looks like:
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce RTX 2060"
    Option         "HardDPMS"  "false"
EndSection
You will need your other work-around (xset dpms force off) as well.
(Hints on the modified driver behaviour were found here)
leu
  • 126
