Whenever I run
mysql -u root mysql
I get an error like:
ERROR 1698 (28000): Access denied for user: 'root@localhost'
I tried running
update user set authentication_string=password('akshansh') where USER='root'
But I got
bash: syntax error near unexpected token `('
Then I ran
$ mysql>FLUSH PRIVILEGES
I still get an error:
ERROR 1045 (28000): Access denied for user: 'root@localhost' (using password: NO)
I've tried all possible solution on Stack Overflow or any other website.
I've also tried deleting and re-installing MySQL. I am still not able to reset the password.
Kulfy
  • 18,154
Use sudo and your current user's password (because within Ubuntu 18.04 the default authentication method for the MySQL's root user is socket authentication):
$ sudo mysql -u root -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 7
Server version: 5.7.29-0ubuntu0.18.04.1 (Ubuntu)
Copyright (c) 2000, 2020, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> show databases;
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| sys                |
4 rows in set (0.00 sec)
mysql>
If I try to log in into mysql DBS without sudo I get the same results:
$ mysql -u root -p
Enter password:
ERROR 1698 (28000): Access denied for user 'root'@'localhost'
In order to use mysql -u root -p you need to create mysql_native_password for the MySQL's root user as it is decried here.
Kulfy
  • 18,154
Gryu
  • 8,002
  • 37
  • 53
