I tried to install "qgis" and "qgis server", but I failed to do so and I think certain packages got conflicted with ones I already have on my system.
Now I can't upgrade through "sudo apt-get upgrade" and also can't install new packages; when I do so I get the following error:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libfcgi-bin : Depends: libfcgi0ldbl but it is not installed
qgis-server : Depends: libfcgi0ldbl but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I also can't purge either qgis-server or libfcgi-bin, if I do so I get:
libfcgi-bin : Depends: libfcgi0ldbl but it is not going to be installed
I want to get rid of qgis-server and anything related to this problem so I can resume the system normally
