I've observed the same behavior on 4 different Linux distributions (mint, manjaro, debian, ubuntu), they show ACPI errors on boot (link of a picture: https://i.sstatic.net/RtxgL.jpg edit: this seems to be an unrelated and harmless bug reported and marked as won't fix on https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1864895 ) and then the systems works fine, but I can't control the screen brightness that is stuck at 100%. This is a huge issue since I work at night and the 300 nits of the screen are burning my eyes, making the laptop unusable while also draining the battery. Looking online, this is a common issue:
Brightness control keys don't work on Lenovo Y540 but xrandr does
https://www.reddit.com/r/Ubuntu/comments/cxygkp/brightness_not_working_on_ubuntu18_nvidia_rtx/
Brightness adjustment not working on Lenovo Y540
https://www.reddit.com/r/pop_os/comments/ckkqod/cannot_change_screen_brightness_lenovo_legion_y540/
but everyone seem to have "fixed" their issue the same way: by changing the bios settings from discrete graphics to switchable graphics. Sadly, my processor is the i7-9750HF variant, which does not include an integrated GPU (that's the meaning of the F part). This means that I only have my RTX 2060 discrete GPU and I'm not able to chose switchable graphics since there is nothing else to switch into.
Here is a list of some of the things I tried and didn't work:
linux kernels tested: 5.4, 5.3, 5.0, 4.15
Nvidia drivers tested: nouveau, 430, 435, 440
BIOS version: BHCN36WW, BHCN35WW
Tried updating
/etc/default/grub acpi_backlight=<all different options>, no luck.xbacklightdoes nothing.ls /sys/class/backlightshows only acpi_video0sudo tee /sys/class/backlight/acpi_video0/brightness <<< 5has no effectthe only thing that works is
xrandr --output DP-2 --brightness 1but that is not a solution since the backlight brightness isn't actually being changed, it just ramps the gamma. This is a software workaround that doesn't actually control the hardware. It also wouldn't help with battery life.
I have tried every solution that I could find or think, but nothing worked. It sounds like something that could be fixed with a BIOS update, since it seems BIOS and ACPI related, but I don't know when or if ever a BIOS update will ever come, is there something on the OS side that could fix this issue?
Please let me know if there is any extra information I should provide and thank you in advance for your help and patience!
system info dump:
- CPU: i7-9750HF
- GPU: Nvidia RTX 2060
- Screen: 1920x1080, 300 nits, 144 Hz
- Laptop: Lenovo Legion Y540 - 15IRH
- Model name: 81SX
- BIOS version: BHCN36WW
PS: Switching secure boot back on makes the brightness control issue go away. But sadly other problems show up, apparently because it loads the nouveau driver and doesn't tell you that it did (the gui will say you are using the proprietary drive but inxi -Gx will tell you the truth that you are using the nouveau one). I was going to try to blacklist it but turns out it was already blacklisted and loaded it anyway.
