sudo apt-get update
Err:1 http://your.repo.domain/repository bionic InRelease
Could not resolve 'your.repo.domain'
Hit:2 http://packages.microsoft.com/repos/vscode stable InRelease
Hit:3 http://download.opensuse.org/repositories/home:/strycore/xUbuntu_18.04 ./ InRelease
Hit:15 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
Err:16 http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu bionic Release
404 Not Found [IP: 2001:67c:1560:8008::15 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Asked
Active
Viewed 2,256 times
Kulfy
- 18,154
PRANJAL TIWARI
- 1
- 1
I'm not sure if you removed the actual repository and replaced it with a custom one, but the first one (assuming that's what you have set up) is not a real repository.
You can remove the repository in one of the following ways:
- software sources
- removing the line for the repository from
/etc/apt/sources.list - if it's not in the above file, look in
/etc/apt/sources.list.ddirectory for the ppa and remove the appropriate file (you could use thermcommand to remove a specific file, but be careful not to delete something you don't want to delete... if you're new, create a test directory and try using thermcommand to delete files from it to verify you don't delete the wrong thing, also avoid usingsudowhen practicing the command to avoid removing important files)
As for the security related issue, I'll need to know which version of ubuntu you have (I'll edit the answer accordingly)
Dan
- 61
- 4
