22
Some time ago I installed Brave but I didn't like it, so I removed it with sudo apt-get remove --purge brave-browser. After some time I had to reinstall it because I needed a Chromium-based browser. As soon as I opened it it asked be to redeem my old BATs, so I deduce that apt-get left something in my system.
Now I don't need Brave anymore and I'm wondering how to remove it completely. I would use sudo apt-get remove --purge brave-browser once more but it looks like it doesn't really remove everything - what command should I use instead?
Ntakwetet
  • 1,676
TIP: Don't forget to export your bookmarks & passwords, just in case you want to import those in some other browser you want to use.
I had to do this all:
sudo apt remove brave-browser
sudo apt purge brave-browser
rm -rf ~/.config/BraveSoftware
rm -rf ~/.cache/BraveSoftware
Reference
Manoj L
  • 476
This error was due to the repository still being in your /etc/apt/sources.list.d
This is how you can remove everything:
apt purge brave-browser brave-keyring
sudo rm /etc/apt/sources.list.d/brave-browser-release.list
sudo apt update
Take note of the sudo command as the sources.list folder is owned by the root
A package stores personal and user specific configuration data in folder ~/.config
It is possible that sudo apt-get remove --purge brave-browser left those configuration files
Try:
cd ~/.config
ls -l | grep brave
If found:
rm -r ~/.config/FOLDER_NAME_HERE
Aravind
  • 943
