I'm following this tutorial on the Ubuntu on how to fix a bug, but am encountering a problem when I try to build the source package. In the section entitled 'Testing the fix', the reader is told to execute two command to complete the build:
$ bzr builddeb -- -S -us -uc
$ pbuilder-dist <release> build ../<package>_<version>.dsc
The first one works fine, and I get a nice collection of packages, including the .dsc file needed to build. However when I fill in the palceholders in the second one and execute it, so it looks like this:
pbuilder-dist precise build ../gedit_3.1.1-0ubuntu4.dsc
I get the following output:
W: /home/notgary/.pbuilderrc does not exist
E: File /home/notgary/pbuilder/precise-base.tgz does not exist
I've followed the PbuilderHowTo on the wiki and have created (I think) a Precise tarball using
sudo pbuilder create --distribution precise
but the only contents of my ~/pbuilder directory is precise_result
What have I done wrong when setting up my build environment, and what do I need to do to fix it so I can build Precise packages using pbuilder?
You first need to create a pbuilder instance locally. To do that, run the command:
pbuilder-dist precise create
This will create the .pbuilderrc and the ~/pbuilder/precise-base.tgz that you are missing.
After that, you can build your .dsc as normal:
jokerdino
  • 41,732
