I've noticed several posts about this same topic, but found no reasonable solution. This post suggests deleting the files, but I want to avoid that since I'm using apache and that same post says that it will break apache. I ran
sudo du -h --max-depth=1
this is the result I get
du: cannot access './run/user/1000/gvfs': Permission denied
du: cannot access './run/user/121/gvfs': Permission denied
2.3M    ./run
du: cannot access './tmp/.mount_jetbraP4UBzE': Permission denied
104K    ./tmp
6.5M    ./libx32
16K ./lost+found
15M ./sbin
5.7G    ./usr
4.0K    ./cdrom
16M ./etc
0   ./sys
0   ./dev
618G    ./var
13M ./bin
4.0K    ./lib64
195G    ./home
4.0K    ./srv
5.8M    ./lib32
936K    ./root
277M    ./boot
1.2G    ./lib
du: cannot read directory './proc/2824/task/2824/net': Invalid argument
du: cannot read directory './proc/2824/net': Invalid argument
du: cannot read directory './proc/2825/task/2825/net': Invalid argument
du: cannot read directory './proc/2825/net': Invalid argument
du: cannot access './proc/5070/task/5070/fd/4': No such file or directory
du: cannot access './proc/5070/task/5070/fdinfo/4': No such file or directory
du: cannot access './proc/5070/fd/3': No such file or directory
du: cannot access './proc/5070/fdinfo/3': No such file or directory
0   ./proc
7.3G    ./snap
14G ./opt
7.1T    ./media
4.0K    ./mnt
7.9T    .
so then I went to /var and
/var$ sudo du -h --max-depth=1
142M    ./cache
60K ./tmp
2.3G    ./www
92K ./spool
6.4M    ./backups
4.0K    ./crash
4.0K    ./mail
4.0K    ./metrics
612G    ./log
3.2G    ./lib
4.0K    ./local
228K    ./snap
4.0K    ./opt
617G    .
so than I tried /var/log
/var/log$ sudo du -h --max-depth=1
208K    ./apt
68K ./cups
24K ./samba
4.0G    ./journal
40K ./mysql
8.0K    ./hp
4.0K    ./gdm3
506M    ./nordvpn
4.0K    ./dist-upgrade
20K ./libvirt
92K ./apache2
28K ./unattended-upgrades
2.7M    ./installer
4.0K    ./speech-dispatcher
612G    .
edit: by request here it is
/var/log$ sudo du -xh -d 3 /var/ | sort -h -r | egrep -v '*K|*M'
617G    /var/
612G    /var/log
4.0G    /var/log/journal/1e5573225229470a9199ad4e005b6533
3.2G    /var/lib
2.5G    /var/lib/snapd
2.3G    /var/www
2.2G    /var/www/pixel
1.3G    /var/lib/snapd/snaps
Now I'm stuck. I have the same problem when I open Disk Usage Analyzer.
How can I free up space on the system? Is this a false positive? In other words it seems like it's reading the free space as used space. Is this a bug?
Pachuca
  • 409
Found a possible solution here, but I wasn't able to determine what was causing this infinite error message to show up. I'm not sure how this will affect my system going forward because I don't see anything going into the log file anymore.
To fix this I had to do
sudo su
because regular sudo gave a Permission denied message. As root I used the solution linked above.
cat /dev/null > /var/log/syslog.1
now my /var/log/syslog.1 is showing as 0 bytes.
Thank you for the help to everyone.
Pachuca
  • 409
