I'd like to add a functionality to a project I'm working on, in which as soon as an external controller device powers on, it sends a time-request/command to a ttyusb port of an Ubuntu PC, and the Ubuntu PC sends back the system's time and date. Does such a command exists in Ubuntu?
for example something like:
'timeReq' > /dev/ttyUSB0
In which "time" is the command that would echo back the system's time
K7AAY
  • 17,705
The command that outputs system time is date.
You can use format parameters to output only the time.
Also you can send its output to USB using > redirection.
Example
date +%R > /dev/ttyUSB0
The user needs to be a mamber of dialout group or have some other permissions to be able to write there.
You can use man date to see for other formatting options.
Pilot6
  • 92,041
