I tried the following command using my Mac Terminal
scp -rp /path/file user@SERVER_IP:/path/destination/folder
It gives me following error:
user@SERVER_IP: Permission denied (public key).
lost connection
Is there any ports that i am missing to open?
Rinzwind
  • 309,379
Maqsud Inamdar
  • 133
Normally, scp asks for a password. To avoid this, or to automate file copying in scripts, public key authentication is usually used. The basic idea is to create a key pair on the client and copy the public key to the server into an authorized keys file.
Sources: https://www.ssh.com/ssh/scp#configuring-public-key-authentication
Elder Geek
  • 36,752
No you are not missing any ports.
Here is an answer:
You need to check if the remote directory(Where you are posting) has permissions for other users.
If not, run: sudo chmod 777 [remote directory]
This should work!
