I have recently gotten an Xbox remote to work on a Raspian using xboxdrv, but when I try to activate it on Ubuntu, I get an error message that says:
Failed to enable unit: Unit file xboxdrv does not exist.
The package xboxdrv is available in the Universe repository. You can find it by searching packages.ubuntu.com.
There is no need to add a PPA, nor should you add a PPA when software is available in Ubuntu repositories. To install this package, simply open a terminal and run the following commands:
sudo apt update
sudo apt install xboxdrv
you have to write an systemd.service by your own.
sudo nano /etc/systemd/system/xboxdrv.service
following content.
[Unit]
Description=Xbox controller driver daemon
[Service]
Type=forking
User=root
PIDFile=/var/run/xboxdrv.pid
ExecStart=/usr/bin/xboxdrv --daemon --detach --pid-file /var/run/xboxdrv.pid --dbus disabled --silent --mimic-xpad
[Install]
WantedBy=multi-user.target
Then you can enable the service.
sudo systemctl enable xboxdrv.service
You have to install xbox driver for linux called xboxdrv. Info: https://xboxdrv.gitlab.io/
Try:
sudo add-apt-repository ppa:grumbel/ppa
sudo apt-get update
sudo apt-get install xboxdrv
