I have TSV file like this:
abc_1
def_2
ghi_3
jkl_4
mno_5
I want to split that in to the:
abc
def
ghi
jkl
mno
and
How I can get that?
With awk:
awk -F_ '{ print $1 > "file_1"; print $2 > "file_2" }' source_file
Method 1
Split by character position:
To obtain the first output (here, the output is redirected to a file called first_output) use:
cut -c1-3 your_input_file >first_output
To obtain the second output use:
cut -c5- your_input_file >second_output
Here, the option -c means "select only the characters specified." The list following the option -c specifies the character positions or ranges (where 1 is the first character in the line).
Method 2
Split according to delimiter:
cut -f1 -d_ your_input_file >first_output
cut -f2 -d_ your_input_file >second_output
Here, the option -d indicates the delimiting character (_ in our case) and the option -f indicates field position to select.
FedKad
  • 13,420
