This happened consistently, after every reboot. I couldn't identify an event that cause it, even happened if I haven't log in.
In the beginning everything seems fine, and I still have commands like ls and ps, but after a few minutes pass Ubuntu starts to crash. First Gnome looses icon layouts and I can't access ls and ps, because Ubuntu can't find the executables. Then I got to the login screen and I can't login with the message: authentication error.
Then I got to a screen where these messages loops forever(at least for 10 minutes it does, after that I turned off the machine with the power button)
The screen I got
I have a Lenovo ThinkPad L590 with CPU: intel core i7-8565u 1.8 Ghz Mem: Samsung ddr4 16 GB Storage: Intel SSDPEKKF512G8L
I already tried the in-built hardware diagnostics, except the extended memory check(I will do that this night but it estimated it to run for 6 hours, so I thought first I should check other things). From the run tests everything passed.
What can cause this issue?
Kovi
  • 13
Fix the file system...
  • boot to a Ubuntu Live DVD/USB
  • open a terminal window by pressing Ctrl+Alt+T
  • type sudo fdisk -l
  • identify the /dev/sdXX device name for your "Linux Filesystem"
  • type sudo fsck -f /dev/sdXX, replacing sdXX with the number you found earlier
    • sudo fsck -f /dev/nvme0n1p1
  • repeat the fsck command if there were errors
  • type reboot
Windows
If you've installed any Windows drivers that allow you to read/write to Linux ext2/3/4 partitions, uninstall it asap, as it's what's been corrupting your SSD.
Check SMART
Start the Disks application. Select your SSD, then review the SMART Data & Tests window. Edit your question and post screenshot(s) of the data.
Check your BIOS
sudo dmidecode -s bios-version # should be 117
https://support.lenovo.com/by/en/downloads/ds540054 to download the newer version.
Check nvme firmware
sudo lshw -C disk # identify firmware version for Intel SSD
Then go to the Intel site and check for newer firmware for the SSDPEKKF512G8L
Check memory
Run your internal memory test, or go to https://www.memtest86.com/ and download/run their free memtest to test your memory. Get at least one complete pass of all the 4/4 tests to confirm good memory. This may take many hours to complete.
Update #1:
Lenovo is sending a replacement nvme drive.
heynnema
  • 73,649
