how are you?
TL;DR: After installing Ubuntu 18.4 LTS, Windows 10 won't start. Windows tries to fix itself and it doesn't work, I had recovery screen. I know it's duplicate, but I swear I did every thing recommended in other questions. And it may be part of problem.
Sorry for wrong naming, I translated options from another language.
For many years I had Windows 7 (gaming) and Ubuntu (work) on dual boot and loved it. 3 days ago I bought Windows 10 and I simply can't make it work. I read so many post and typed so many commands, that it can be something I did previously. I hope I'm not wasting your time.
What I did:
- I installed Windows 10, I was working
- I installed Ubuntu 18.04 LTS with option "Install next to Windows"
- After that windows booted, I checked Windows mode and it's UEFI
- I changed loader to GRUB in BIOS and choose boot mode to UEFI (instead of UEFI and Legacy)
- I saw GRUB menu and choose Ubuntu. It's working :)
- I restarted computer and choose Windows in GRUB menu
- Windows started loading, but it tried to fix itself. It didn't work and showed me "Close system" or "Advanced Options". I looked at Advanced Options and didn't know what to do, so I googled the problem.
- I downloaded boot-repair, choose Standard fix, it added many options to GRUB menu, but none of them is working
- I choose advanced options in boot-repair and checked if GRUB localization has boot/efi partition checked. Yes, It's checked.
- MBR Options are greyed out
- Repair Windows boot files is greyed out, I read something about it, but I still don't know why.
- In BIOS I have disabled secure boot. Windows still doesn't load.
- I disabled Windows fast boot via command (HiberbootEnabled). Windows still doesn't load correctly.
- I tried first answer from 217904 question and problem is still the same.
But now I have some report: http://paste.ubuntu.com/p/2sfszV23XB/ I read it and there are some issues, but I don't have knowledge to understand it.
My Grub config:
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
UEFI test:
kamila@UBUNTU-STACJONARnY:~$ [ -d /sys/firmware/efi ] && echo "EFI boot on HDD" || echo "Legacy boot on HDD"
EFI boot on HDD
Please, can someone help me? I tried to fix it for 3 days.
EDIT: It's same as Windows 10 (dual boot) doesn't start anymore!, but only answer is reinstall Windows, because you installed Windows on wrong partition. I had one partition with Windows and it was Ubuntu installed who separated partitions.
EDIT: I changed Windows OS Configuration in BIOS from CSM to UEFI. Windows is still not working.
RESOLVED: I tried to fix Windows installation for many hours, but only reinstalling Windows helped.
- be sure to set BIOS options before installation. I changed all options to UEFI (Windows OS Configuration && Boot mode)
- I deleted all partitions,
- be sure you have only one hard drive installed (I had second drive with backup files while windows installation, maybe it was that? But Windows worked without it and I plug it out after Windows installation)
- be sure you have hibernation off
- Now you can install Windows and Ubuntu
Sorry for taking you time and I hope this post will help someone :)
