I got error in my laravel project 413 (Payload too large) on ajax post.
Now I edited the post_max_size & upload_max_filesize on php.ini file in my /etc/php/7.1/cli/php.ini.
Now I want to restart apache server since I updated the php.ini file.
I have done this
/etc/init.d/apache2 restart
And still got the error.
Is there something missing? Hope anyone can help me. Thanks
Jin
You can restart server by following command
sudo systemctl restart apache2
Hope this will work for you
Faizan Sadiq
  • 146
as stated in the comment, thats true. You have to modify correct ini at correct path. You have just changed only the cli configuration (PHP called from bash or so (cli)).
So the path should be: /etc/php/7.1/apache2/php.ini.
But it depend on Your distro .. etc
jobrik
  • 116
If you use php-fpm you will need to restart this service too. Try
systemctl restart php7.<X>-fpm.service
where X is the version number of your php
s1mmel
  • 2,124
Press ctrl+Alt+t then run this command
sudo service apache2 restart
