GoldenDict worked fine but one day simply stopped launching. The process is there, takes 29.4 MBs of storage, but the app doesn't launch. I uninstalled it and reinstalled again. No luck so far. What do I do?
K7AAY
  • 17,705
Catman
  • 31
After removing and before installing goldendict, do: mv ~/.goldendict ~/.goldendict.bk in case if your user's goldendict configuration files were corrupted.
Maybe you've tried to reinstall it using sudo apt remove goldendict && sudo apt install goldendict, which doesn't purge all package files, which could be broken. To reinstall goldendict use the next command:
sudo apt purge goldendict libeb16 libopencc2 libopencc2-data
sudo apt update && sudo apt upgrade \
Also, you could install it using snap:
sudo snap install goldendictionary --classic
to check if it works, however it has the same version, so if purging/installing helps, it is not needed to install it using snap.
Also, as @SadaharuWakisaka mentioned, you could have issues with Wayland trying to launch goldendict. Try to launch it using:
Exec=env QT_QPA_PLATFORM=xcb goldendict
Gryu
  • 8,002
  • 37
  • 53
