Everytime, after having started my computer, I get the following notification:
the file P(long number).MOV is being uploaded to you personal cloud.
Does anybody know what this means? I can not find such a file in my folder.
Cheers!
Corina
Cheers!
Corina
The notification means Ubuntu One is synchronizing that file. The file must therefore be inside a folder being synchronized by Ubuntu One. The filename looks like a video recorded from a digital camera or camcorder. If you are synchronizing your ~/Videos folder with Ubuntu One, it may very likely be in there.
If you keep seeing the same filename, it is likely taking a very long time to upload, or may actually be a different file being uploaded, but due to a bug (which has since been fixed), you may be seeing the notification with a filename that is no longer being uploaded. Can you please specify what versions of Ubuntu itself, and the ubuntuone-client package you have installed?
To see what Ubuntu One is currently working on you can open a terminal and run the two following commands:
u1sdtool --current-transfers
u1sdtool --waiting
These should print a list of the current, and pending transfers, respectively.
Be shure that the file is not hidden. To show hidden files presh ctrl + h. Then search for the file. Hidden file are preceded by a dot ".". If you can't find the file, please make sure that the file are in the place you are searching.
Also you can try, in a command line:
cd /
updatedb
locate name_of_the_file
And will show you all the files matching this name. If you haven't got installed "locate" package, please, install from ubuntu software center.
I hope it helps you!
