I followed the first and fourth comments of this post but I couldn't install firefox dev.
Actually I don't really know if the browser was installed, every step of the fourth comment seems to work, but when I tried use gksu gedit /usr/share/applications/firefox-dev to create the icon the terminal returned the following error:
Command 'gksu' not found
I search and found out that gksu is deprecated, so one alternative presented was pkexec, and I tried:
pkexec gedit /usr/share/applications/firefox-dev.desktop
The termonal returned this error:
Unable to init server: Could not connect: Connection refused
(org.gnome.gedit:2744): Gtk-WARNING **: 22:07:54.667: cannot open display:
  1. How I make sure that the firefox developer is installed and how do I open it from the terminal?
  2. How to create an executable icon to it?
trayingHardFi
  • 61
As taliezin answered in https://unix.stackexchange.com/questions/203136/how-do-i-run-gui-applications-as-root-by-using-pkexec I tried and worked fine.
It can be done by adding custom actions to policykit.
If you want to run gedit as root with pkexec you have to create new file /usr/share/polkit-1/actions/org.freedesktop.policykit.gedit.policy for example:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE policyconfig PUBLIC
 "-//freedesktop//DTD PolicyKit Policy Configuration 1.0//EN"
 "http://www.freedesktop.org/standards/PolicyKit/1/policyconfig.dtd">
<policyconfig>
    <action id="org.freedesktop.policykit.pkexec.gedit">
    <description>Run gedit program</description>
    <message>Authentication is required to run the gedit</message>
    <icon_name>accessories-text-editor</icon_name>
    <defaults>
        <allow_any>auth_admin</allow_any>
        <allow_inactive>auth_admin</allow_inactive>
        <allow_active>auth_admin</allow_active>
    </defaults>
    <annotate key="org.freedesktop.policykit.exec.path">/usr/bin/gedit</annotate>
    <annotate key="org.freedesktop.policykit.exec.allow_gui">true</annotate>
    </action>
</policyconfig>
Finally pkexec gedit should work as expected.
Read the man pkexec which explains it examples.
danilo
  • 1,865
