I seem to have messed up the partition table of my mobile phone, and I was wondering whether I can recreate it from the gdisk output that I still have, using the Ubuntu installation on my laptop.
This is the output of gdisk -l /dev/sdb before things went wrong:
Found valid GPT with protective MBR; using GPT.
Disk /dev/sdb: 61071360 sectors, 29.1 GiB
Model: MMC Storage
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Partition table holds up to 36 entries
Main partition table begins at sector 2 and ends at sector 10
First usable sector is 34, last usable sector is 61071326
Partitions will be aligned on 2-sector boundaries
Total free space is 257992 sectors (126.0 MiB)
Number Start (sector) End (sector) Size Code Name 1 32768 163839 64.0 MiB 0700 modem 2 163840 165887 1024.0 KiB FFFF sbl1 3 165888 166911 512.0 KiB FFFF dbi 4 196608 197631 512.0 KiB FFFF DDR 5 229376 231423 1024.0 KiB FFFF aboot 6 231424 233471 1024.0 KiB FFFF rpm 7 262144 294911 16.0 MiB FFFF boot 8 294912 296959 1024.0 KiB FFFF tz 9 296960 296961 1024 bytes 0700 pad 10 327680 333823 3.0 MiB FFFF modemst1 11 333824 339967 3.0 MiB FFFF modemst2 12 339968 339969 1024 bytes FFFF pad1 13 360448 393215 16.0 MiB FFFF misc 14 393216 458751 32.0 MiB 0700 persist 15 458752 491519 16.0 MiB FFFF recovery 16 491520 497663 3.0 MiB FFFF fsg 17 524288 525311 512.0 KiB FFFF fsc 18 525312 526335 512.0 KiB FFFF ssd 19 526336 526337 1024 bytes FFFF pad2 20 526338 527361 512.0 KiB FFFF encrypt 21 557056 573439 8.0 MiB 0700 drm 22 573440 589823 8.0 MiB 0700 sns 23 589824 655359 32.0 MiB FFFF laf 24 655360 720895 32.0 MiB FFFF fota 25 720896 786431 32.0 MiB 0700 mpt 26 786432 787455 512.0 KiB FFFF dbibak 27 787456 789503 1024.0 KiB FFFF rpmbak 28 789504 791551 1024.0 KiB FFFF tzbak 29 791552 791567 8.0 KiB FFFF rct 30 819200 6488063 2.7 GiB 0700 system 31 6488064 7733247 608.0 MiB 0700 cache 32 7733248 7897087 80.0 MiB 0700 tombstones 33 7897088 7929855 16.0 MiB 0700 spare 34 7929856 8028159 48.0 MiB 0700 cust 35 8028160 60948479 25.2 GiB 0700 userdata 36 60948480 61071326 60.0 MiB 0700 grow
This is the output now:
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Warning! Main partition table overlaps the first partition by 32 blocks! You will need to delete this partition or resize it in another utility.
Warning! Secondary partition table overlaps the last partition by 33 blocks! You will need to delete this partition or resize it in another utility. Disk /dev/sdb: 2014208 sectors, 983.5 MiB Model: Mighty Drive
Sector size (logical/physical): 512/512 bytes Disk identifier (GUID): F53C299E-4571-4252-8AAA-29494104F80C Partition table holds up to 128 entries Main partition table begins at sector 2 and ends at sector 33 First usable sector is 34, last usable sector is 2014174 Partitions will be aligned on 2-sector boundaries Total free space is 0 sectors (0 bytes)
Number Start (sector) End (sector) Size Code Name 1 2 2014207 983.5 MiB 0700 Microsoft basic data
The output of ls /dev/sdb* only displays /dev/sdb15 now, and nothing else. /dev/sdb15 used to be the recovery partition in the output above, which I appear to have messed up, as well as the partition table, using dd with an invalid input file in conjunction with of=/dev/sdb15.
Could this be the way to go, using fdisk, putting it into sector mode with the u command, and then using d and n to delete and create the partitions on /dev/sdb?
I have already made some painful mistakes to get me into this mess, and I'm reluctant to mess things up any further before knowing exactly what to do (and why).
