My hardware: laptop HP Elitebook 6930p, Intel Core duo, stock Radeon graphics controller
My OS sw: Ubuntu MATE 18.04.4
problem description:
  • with kernel 4.15.0-76 resume from suspend WORKS OKAY, as with all previous kernels since first installation of Ubuntu MATE
  • since updating kernel to 4.15.0-88 few weeks ago, resume from suspend DOES NOT WORK, system goes to suspend, but does not resume by pushing the power button, display blinks few times, stays black with cursor in top left corner. Reboot starts system again normally.
  • trying to solve problem by upgrading kernel to 5.3.0-40 but resume from suspend DOES NOT WORK, same problem like with kernel 4.15.0-88. Reboot starts system again normally.
  • now having all mentioned kernels installed, and when selecting kernel 4.15.0-76 in grub, and starting system, resume from suspend works okay when pushing power button.
Seen many similar problem description at site, but not found working solution so far.
What should I do to fix this?
Data check: Kernel 4.15.0-76
sh@HP-MATE:~$ uname -a
Linux HP-MATE 4.15.0-76-generic #86-Ubuntu SMP Fri Jan 17 17:24:28 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
sh@HP-MATE:~$ sudo blkid
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: UUID="0b348867-07da-457d-a3bd-53c7eadc9ac4" TYPE="ext2" PARTUUID="78d29c15-01"
/dev/sda5: UUID="PoP2Ze-xEsB-TRpm-R9iz-10Ed-hv8a-mp8Gq5" TYPE="LVM2_member" PARTUUID="78d29c15-05"
/dev/mapper/ubuntu--mate--vg-root: UUID="431a67b1-bfd1-4f23-b898-41774cf7bb22" TYPE="ext4"
/dev/mapper/ubuntu--mate--vg-swap_1: UUID="fff000a6-83df-4543-86bb-5ae567068ccd" TYPE="swap"
/dev/loop8: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop14: TYPE="squashfs"
/dev/loop15: TYPE="squashfs"
/dev/loop16: TYPE="squashfs"
/dev/loop17: TYPE="squashfs"
/dev/loop18: TYPE="squashfs"
/dev/loop19: TYPE="squashfs"
/dev/loop20: TYPE="squashfs"
/dev/loop21: TYPE="squashfs"
/dev/loop22: TYPE="squashfs"
sh@HP-MATE:~$ free -h
total used free shared buff/cache available
Mem: 3,8G 888M 1,2G 28M 1,8G 2,6G
Swap: 4,0G 0B 4,0G
sh@HP-MATE:~$ cat /etc/initramfs-tools/conf.d/resume
RESUME=UUID=fff000a6-83df-4543-86bb-5ae567068ccd
sh@HP-MATE:~$ cat /etc/fstab
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a device; this may be used with UUID= as a more robust way to name devices that works even if disks are added and removed. See fstab(5).
/dev/mapper/ubuntu--mate--vg-root / ext4 errors=remount-ro 0 1
"#/boot was on /dev/sda1 during installation"
UUID=0b348867-07da-457d-a3bd-53c7eadc9ac4 /boot ext2 defaults 0 2
/dev/mapper/ubuntu--mate--vg-swap_1 none swap sw 0 0
Data check: Kernel 4.15.0-88
Linux HP-MATE 4.15.0-88-generic #88-Ubuntu SMP Tue Feb 11 20:11:34 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Mem: 3,8G 815M 2,1G 23M 897M 2,8G
Swap: 4,0G 0B 4,0G
haksep
