1 Intel i3-8100/32GB pc ("FujitsuServer" with ip 192.168.88.10) and 1 Intel i5-8350/8GB laptop ("Laptop-A" with ip 192.168.88.22) both with fresh Ubuntu Budgie 19.10 installs.
I have enabled Desktop sharing and Media sharing on the PC. I have installed a Brother printer successfully via USB, works fine. I can access localhost:631 and see CUPS, printer sharing is enabled.
I can PING both computers from each other.
PROBLEM:
- Laptop, when using Remmina, I cannot access the pc via vnc, "FujitsuServer.local" does nothing, no connection can be made.
- Lapto, file manager > Network I can see "FUJITSUSERVER" but I get a "Connection refused" error.
- I can find the shared printer on the laptop, but I cannot print anything to it.
- The cups webUI of the PC is also not accessible via the laptop (going to 192.168.88.10:631 leads to a timeout).
I even tried connecting both directly with each other via a networkcable, assigning IP addresses manually. PING works. But just like with a router between them, nothing else.
How is sharing suppose to work?
