When using Dropbox in Ubuntu everything seems fine, but on my Windows machine with Dropbox I end up with the file.ext~ backup/temp version of any files I opened in Ubuntu. Is there some way to prevent this? I found several forum topics about this matter on the Dropbox forum but they are all expired and unviewable. (Side note: why would you hide your forum's aggregated knowledge?)
No current way to do it. Your best bet is to disable autosaving of the gedit files (I'm assuming thats the app you are using):
Prevent gedit from creating files with the '~' (tilde) suffix
Also, vote up this feature request with Dropbox for the option:
https://www.dropbox.com/votebox/2385/option-to-exclude-by-file-extension
EDIT: the above link is broken as Votebox is discontinued. You may want to go here instead: https://forums.dropbox.com/topic.php?id=59743
If they ever implement that, it should work for your uses (file ext would just be ~)
