My question is, how is software not listed in Ubuntu Software Center uninstalled?
Asked
Active
Viewed 4,488 times
If it came from apt you can use
sudo apt remove {package-name} or sudo apt purge
If it came from a deb file outside of the repo's.
apt-get remove
works as well.
Joeri_Damian
- 29
If you've installed software using installation scripts, that puts binaries, libraries, config files to different directories, than you should remove those files by your own looking into script and analyzing where and what it copied. Use
rmcommand if no uninstall script present.If you've installed it using
make install, then try to usemake uninstallcommand in the same directoryIf you've installed software using other package systems, use them for uninstalling. For example:
sudo snap remove gimpBefore uninstalling read documentation to software you're trying to uninstall. Maybe there're uninstall steps described
Gryu
- 8,002
- 9
- 37
- 53
