I tried to clean some packages up and wound up screwing something up.
Now, it no longer boots to a graphic window: I get a terminal login screen.
I'm using xfce4 and I can use the startx command to enter the graphical environment, but I'd prefer to go straight to a graphic login, user-screen and so on.
Ubuntu 18.04 latest.
Clean away the wreckage of the old Desktop Environment before reinstalling xfce by
sudo apt purge  '~n^libxfce4.*' '~n^libexo.*' '~n^libgarcon.*'
sudo apt-get install xubuntu-desktop
K7AAY
  • 17,705
I think I found out what was going wrong but not why.
In /var/log/syslog I see:
 lightdm.service Main process exited, coe=exited, status=1/FAILURE
 lightdm.service failed with result 'exit-code'
I then followed the suggestion given here ... Lightdm not starting on boot ...
... and used the dpkg-reconfigure command to choose gdm3.
Magically, it worked!
