When I wanted to run sudo apt install gnome-shell-extension-ubuntu-dock, came up with an error:
Reading package lists... Done
Building dependency tree
gnome-shell-extension-ubuntu-dock is already the newest version (0.9.1ubuntu18.04.3).
You might want to run 'apt --fix-broken install' to correct these.
 cuda-libraries-dev-10-2 : Depends: libcublas-dev (>= 10.2.2.89) but it is not going to be installed
 cuda-samples-10-2 : Depends: libcublas-dev (>= 10.2.2.89) but it is not going to be installed
 cuda-visual-tools-10-2 : Depends: libcublas-dev (>= 10.2.2.89) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I searced across the web and tried different solutions. In conclusion, when I run sudo apt install -f, the output is:
Get:1 file:/var/cuda-repo-10-2-local-10.2.89-440.33.01  libcublas-dev 10.2.2.89-1 [42,3 MB]
(Reading database ... 292882 files and directories currently installed.)
Preparing to unpack .../libcublas-dev_10.2.2.89-1_amd64.deb ...
Unpacking libcublas-dev (10.2.2.89-1) ...
dpkg: error processing archive /var/cuda-repo-10-2-local-10.2.89-440.33.01/./libcublas-dev_10.2.2.89-1_amd64.deb (--unpack):
 trying to overwrite '/usr/include/nvblas.h', which is also in package nvidia-cuda-dev 9.1.85-3ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Then I tried to sudo apt remove nvidia-cuda-dev. The output is:
 nvidia-cuda-toolkit : Depends: nvidia-cuda-dev (= 9.1.85-3ubuntu1) but it is not going to be installed
Even when I run sudo apt purge nvidia* or cuda*, the output is:
 cuda-drivers : Depends: nvidia-compute-utils-440 (>= 440.33.01) but it is not going to be installed
                Depends: nvidia-dkms-440 (>= 440.33.01) but it is not going to be installed
                Depends: nvidia-driver-440 (>= 440.33.01) but it is not going to be installed
                Depends: nvidia-kernel-common-440 (>= 440.33.01) but it is not going to be installed
                Depends: nvidia-kernel-source-440 (>= 440.33.01) but it is not going to be installed
                Depends: nvidia-utils-440 (>= 440.33.01) but it is not going to be installed
                Depends: nvidia-modprobe (>= 440.33.01)
                Depends: nvidia-settings (>= 440.33.01) but it is not going to be installed
This really took all of my energy. Can someone help please?
emremrah
  • 121
