27
What do I want to do?
You can have
deb [trusted=yes] http://pathtoserver/ubuntu bionic main
deb [arch=amd64] http://pathtoserver/ubuntu bionic main
in sources.list separately.
Is there a way I can do
deb [trusted=yes, arch=amd64] http://pathtoserver/ubuntu bionic main or something like that where I can have only amd64 as options and trusted should be yes. in Ubuntu 18.04 Bionic.
Error
If I use the following deb line
deb [arch=amd64 trusted=yes] http://pathtoserver/ubuntu bionic main
E: Conflicting values set for option Trusted regarding source
E: The list of sources could not be read.
This is an airgapped system and I have mirrored the ubuntu repository for offline purpose.
As you saw thanks to @Terrance's comment, you need to put the option like this : [trusted=yes arch=amd64] (in no particular order).
Regarding your second error, it would be because you have another entry that uses the same URL (http://pathtoserver/ubuntu) but does not have the [trusted=yes].
For example, if you have one entry for Releases and one entry for Sources, they both need to have the [trusted=yes].
Mickael V.
  • 396
