I need to install a local SSL certificate so that the browser trusts it. The tutorial Running Angular CLI over HTTPS with a Trusted Certificate has instructions for OS X and Windows, but not Ubuntu.
For example these are the instructions for OS X:
  1. Double click on the certificate (server.crt)
  2. Select your desired keychain (login should suffice)
  3. Add the certificate
  4. Open Keychain Access if it isn’t already open
  5. Select the keychain you chose earlier
  6. You should see the certificate localhost
  7. Double click on the certificate
  8. Expand Trust
  9. Select the option Always Trust in "When using this certificate"
  10. Close the certificate window
The certificate is now installed.
What would the equivalent be for Ubuntu?
Eliah Kagan
  • 119,640
Ole
  • 1,527
This will do the trick: How do I install a root certificate?
Also these explanations are about a self-signing certificate and not about a CA (certificate Authority)on a server Apache!
To install openssl:
apt-get install openssl
To generate the private key:
openssl genrsa -aes256 -out certificat.key 4096
We rename the key :
mv certificat.key certificat.key.lock
Then generate our unlocked certificate:
openssl rsa -in certificat.key.lock -out certificat.key
Private key unlocked : certificat.key
Locked private key : certificat.key.lock
Generation of the signature request file:
openssl req -new -key certificat.key.lock -out certificat.csr
To auto-sign your certificate:
openssl x509 -req -days 365 -in certificat.csr -signkey certificat.key.lock -out certificat.crt
With Apache:
a2enmod ssl
/etc/apache2/site-availables/tuto.conf
<VirtualHost *:80>
    ServerName      tuto.myaddrsite.com
    # Redirect HTTP port to HTTPS port
    Redirect        / https://www.myaddrsite.com
</VirtualHost>
<VirtualHost *:443>
    DocumentRoot    /var/www/tuto
SSLEngine on
SSLCertificateFile    /etc/ssl/www/certificat.crt
SSLCertificateKeyFile /etc/ssl/www/certificat.key
SSLProtocol all -SSLv2 -SSLv3
SSLHonorCipherOrder on
SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES
</VirtualHost>
To activate vHost :
a2ensite tuto.conf
service apache2 restart
After that, I don't know how to proceed with Angular. My description is for Apache, but you always could find some interesting descritption by simple search on your browser. Or maybe somebody will coming to complete my description :)
Ole
  • 1,527
koalatree
  • 111
