I just upgraded from Ubuntu 18.04 to 19.10. After upgrade I noticed that pgAdmin4 got removed while other softwares are still present and now when I try to install pgadmin4 from the terminal, I get:
The following packages have unmet dependencies: pgadmin4 : Depends: pgadmin4-common (= 4.18-1.pgdg18.04+1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I have installed pgadmin3 but I really want pgadmin4. Is that possible?
Kulfy
  • 18,154
As far I can understand the pgadmin4 package was installed from third-party repository.
Quick search gives me this page - https://atalia.postgresql.org/morgue/p/pgadmin4/ .
So you have to open Software & Updates (software-properties-gtk) and enable line similar to above.
Or add this repository again as described in http://wiki.postgresql.org/wiki/Apt:
sudo apt-get install curl ca-certificates gnupg lsb-release
curl https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add -
sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt $(lsb_release -cs)-pgdg main" > /etc/apt/sources.list.d/pgdg.list'
sudo apt-get update sudo apt-get install pgadmin4
N0rbert
  • 103,263
