18
Hello I'm using Ubuntu 12.04 Beta 2 and I've got the .debs of the softwares I had been using in Oneiric. I wanna install them all!! But the problem is I can't install them one by one [due to shortage of time and patience].
Is there any command to install all the .debs placed in a single folder once and for all!!
Suchith JN
  • 2,181
here is how Click the Dash -> type Terminal
open up the terminal
then type cd PATH_TO_THE_FOLDER_CONTAINING_THE_DEBS
then run
sudo dpkg -i *.deb
basically, what this does is fills in the rest of the name in place of the * character. You may encounter an error saying dependencies not met, if you see this then you can run
sudo apt-get install -f
This usually will cause apt to download the missing dependencies.
zeitue
  • 2,226
This command should help.
Go into the folder using the terminal and then type:
sudo dpkg -i *.deb
Sakti
  • 226
dpkg -R does a recursive directory install.
sudo dpkg -R /path/to/folder
Kulfy
  • 18,154
Bonus
  • 19
