After a recent update from ubuntu 19.10, I reboot my PC. After reboot, I discovered that there is no wifi-Adapter available. To install wifi Adapter manually I tried the command :
sudo lshw -C network
It produces the following output
    *-network
   description: Network controller
   product: Intel Corporation
   vendor: Intel Corporation
   physical id: 14.3
   bus info: pci@0000:00:14.3
   version: 00
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list
   configuration: driver=iwlwifi latency=0
   resources: irq:16 memory:a4318000-a431bfff
 *-network
   description: Ethernet interface
   physical id: 3
   bus info: usb@1:6
   logical name: enp0s20f0u6
   serial: de:ad:12:86:9b:1f
   capabilities: ethernet physical
   configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.170 link=yes multicast=yes
To investigate detail about the wireless PCI I also tried the following
lspci -nnk | grep 0280 -A2
which shows,
00:14.3 Network controller [0280]: Intel Corporation Device [8086:02f0]
Subsystem: Intel Corporation Device [8086:0034]
Kernel driver in use: iwlwifi
I am in a fix what to do or how/which driver to install.
BTW, I cant not find the manufacturer of the wireless device.
