I am using Ubuntu 16.04 and I have been using Gimp for long time. Out of a sudden it refused to open complaining about:
libstdc++.so.6: cannot open shared object file: No such file or directory
I tried to install this library using:
$sudo apt-get install libstdc++6
or even (for 32bit although I don't think I am using a 32bit version): $sudo apt-get install lib32stdc++6
to no avail. I tired copying the existing libraries to the Gimp folder but since I have install it via snap it failed stating it's a read only system.
Then, I tried removing Gimp and reinstall it but it also failed (the installation part) stating:
libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
I have managed to install it via $sudo apt install gimp but the installed version is too old to be satisfactory (2.8.16).
So, how can I install (via snap preferably) gimp in my system? And how come it stopped working all of a sudden (not even a reboot took place between the working and not working phase of Gimp by the way).
Eypros
  • 531
Apparently the version which snap tried to update to (or managed to update to) has some bugs which prevents it from being executed.
The revision that failed in my case is 245 (I think the version is 2.10.14). As I mentioned I tried to reinstall it but to no avail, so, I tried the candidate (rev 246) channel which does not seem to suffer from the same bug:
$sudo snap install --channel=candidate gimp
I hope that the developers will fix the bug and I can use the stable channel once again or alternatively that the candidate is stable enough to not cause me a lot of trouble.
P.S.
For some reason I could not manage to install Gimp 2.10 via PPA in Ubuntu 16.04
Eypros
  • 531
