I try to install sudo apt-get install boinc But i try to install another parkket but i can't install any software on the computer it just says: (sudo apt-get install boinc)
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 boinc : Depends: boinc-client (>= 7.6.31+dfsg-6ubuntu1) but it is not going to be installed
         Depends: boinc-manager (>= 7.6.31+dfsg-6ubuntu1) but it is not going to be installed
 nvidia-cuda-toolkit : Depends: nvidia-cuda-dev (= 7.5.18-0ubuntu1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
then i run sudo apt-get -f install still does not working !
How can we fix the issues??
Edit 20-02-2020 21:34 Here is my sudo apt-get update
hostings@hostings:~$ sudo apt-get update
Get:1 file:/var/cuda-repo-10-2-local-10.2.89-440.33.01  InRelease
Ign:1 file:/var/cuda-repo-10-2-local-10.2.89-440.33.01  InRelease
Get:2 file:/var/cuda-repo-10-2-local-10.2.89-440.33.01  Release [574 B]
Hit:3 http://dk.archive.ubuntu.com/ubuntu xenial InRelease
Hit:4 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:5 http://dk.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:6 http://ppa.launchpad.net/ethereum/ethereum/ubuntu xenial InRelease
Hit:7 http://dk.archive.ubuntu.com/ubuntu xenial-backports InRelease
Ign:8 http://webmin.mirror.somersettechsolutions.co.uk/repository sarge InRelease
Hit:10 http://webmin.mirror.somersettechsolutions.co.uk/repository sarge Release
Ign:11 http://download.webmin.com/download/repository sarge InRelease
Hit:12 http://download.webmin.com/download/repository sarge Release
Edit 21-02-2020 11:03
I run this command here: (sudo apt-get -f install)
Correcting dependencies... Done
The following additional packages will be installed:
  nvidia-cuda-dev
Recommended packages:
  libnvcuvid1
The following NEW packages will be installed:
  nvidia-cuda-dev
0 upgraded, 1 newly installed, 0 to remove and 44 not upgraded.
1 not fully installed or removed.
Need to get 0 B/201 MB of archives.
After this operation, 467 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 194785 files and directories currently installed.)
Preparing to unpack .../nvidia-cuda-dev_7.5.18-0ubuntu1_amd64.deb ...
Unpacking nvidia-cuda-dev (7.5.18-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-cuda-dev_7.5.18-0ubuntu1_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/stubs/libcublas.so', which is also in package libcublas-dev 10.2.2.89-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
fredy4
  • 19
you could try this:
sudo apt-get autoclean
then:
VETAOSX
