39
I'm working with Ubuntu 16 and Cuda toolkit 10.2.
I'm using installer file: cuda_10.2.89_440.33.01_linux.run.
I understand I need to remove something I previously installed but don't know what exactly.
Any suggestions will be appreciated.
K7AAY
  • 17,705
If you only want to install the cuda toolkit to /usr/local, please run:
sudo sh ./cuda_10.2.<spec>.run --toolkit --silent --override
If you need nvidia driver as well, you could try the answer provided by Albino Cordeiro
Running dpkg -l | grep Nvidia and then sudo apt purge ... did the trick.
Warning: above will uninstall your current nvidia driver.
user3026714
  • 361
Just run into this exact problem in Ubuntu18.04. And after some search, my solution is the following:
  1. If you are sure that your driver version matches the cuda-toolkit version you are gonna install, refer to @domainxz answer, add --toolkit to only install toolkit and not to care about nvidia driver. Check this link for compatibility. (Scroll down to CUDA Driver table).
  2. If you want CUDA to handle the compatibility problem for you, you need to uninstall your current drivers. Follow the instructions in the official documentation. After you entered the text screen after reboot, uninstall your previous Nvidia driver and run the cuda runfile. For Ubuntu 18.04, this is what I did and worked:
    sudo apt-get remove --purge nvidia\*
    sudo apt-get autoremove
    sudo sh cuda-*.run --silent --override
The official documentation is actually very detailed... Just make sure you follow each step and you should be fine.
Yuan Tao
  • 261
I managed to solve my problem. I manage a large number of identical servers and usually use a .run file (cuda_10.2.89_440.33.01_linux.run) to install the Cuda toolkit. On this one specific server, I did some experiments a while ago and forgot that I installed the previous version of Cuda differently there (using sudo apt install). Running dpkg -l | grep Nvidia and then sudo apt purge ... did the trick.
got in rootm with
$ sudo su
then
# for FILE in $(dpkg-divert --list | grep nvidia-340 | awk '{print $3}'); do dpkg-divert --remove $FILE; done
then
# apt --fix-broken install
