Trying to install Rabbitmq to AWS Ubuntu 18.04. First I need to install Erlang:
wget -O- https://packages.erlang-solutions.com/ubuntu/erlang_solutions.asc | sudo apt-key add -
echo "deb https://packages.erlang-solutions.com/ubuntu bionic contrib" | sudo tee /etc/apt/sources.list.d/rabbitmq.list
sudo apt update
sudo apt -y install erlang
Erlang version 22 installed.
Now installing Rabbitmq:
echo "deb https://dl.bintray.com/rabbitmq/debian $(lsb_release -sc) main" | sudo tee /etc/apt/sources.list.d/rabbitmq.list
This brought line below to /etc/apt/sources.list.d/rabbitmq.list: deb https://dl.bintray.com/rabbitmq/debian bionic main
sudo apt update
sudo apt -y install rabbitmq-server
This brings error:
 rabbitmq-server : Depends: erlang-nox (>= 1:13.b.3) but it is not going to be installed or
                            esl-erlang but it is not installable
What is wrong with Erlang? According description Erlang 22 should support Rabbitmq 3.8.
How to fix it?
vico
  • 4,717
  • 23
  • 66
  • 89
See this gist for a series of commands to install Erlang and RabbitMQ on Ubuntu:
https://gist.github.com/lukebakken/bd90852537928b4f8801bae9aa051bf0
Change xenial to your version.
NOTE: the RabbitMQ team monitors the rabbitmq-users mailing list and only sometimes answers questions on StackOverflow.
Luke Bakken
  • 111
