Hardware: Lenovo Thinkpad Carbon X1 2019, using an Intel AC 9560 wireless module
Upon installing Ubuntu 18.04, I discovered that my Wi-Fi worked while installing Ubuntu, but did not after I restarted. It turns out that this problem occurs during the update process. Turns out it was the kernel! Worked on 5.3.0-28 but broken on 5.3.0-40
Specifically, you know you have the problem I experienced if you see the following behavior:
-The Wi-Fi settings page indicates that it cannot find a wireless module.
-You were able to see Wi-Fi networks while installing Ubuntu
-If you reboot Ubuntu using "Advanced Options for Ubuntu" at the startup screen and select an older kernel version (not recovery mode), your wireless works again
4b0
  • 155
Solved problem by removing the offending updated kernel (sudo apt purge linux-image-5.3.0-40-generic) and swearing not to update my kernel in the future (judge me, I know!)
If someone wants to dig in and try to solve the issue in a more graceful way, then have at it! This is satisfactory for me.
Other possibly relevant links:
This answer was originally posted by Ryan Monroe inside the question.
Melebius
  • 11,750
4b0
  • 155
