I've solved it, but the solution is not very nice.
Copy lowlatency grub configuration file into new custom grub config file: sudo cp /etc/grub.d/09_lowlatency /etc/grub.d/08_custom
I got 09_lowlatency file by following instructions:
First, let’s visit https://packages.ubuntu.com/. This step is a little
less obvious. The package “ubuntustudio-default-settings” contains a
file named “09_lowlatency”. This file is a GRUB configuration file we
can use to assure our lowlatency kernel is booted first and assures it
will stay that way.
Take away these files so they will not duplicate grub menu entries and will not be duplicated in a list during sudo update-grub2 command execution:
sudo mv /etc/grub.d/10_linux /home/myuser/backup/ && sudo mv /etc/grub.d/09_lowlatency /home/myuser/backup/
I changed one case statement in the 08_custom file:
Before changing it was:
case "x$machine" in
xi?86 | xx86_64)
list=
for i in /boot/vmlinuz-*lowlatency /vmlinuz-*lowlatency /boot/kernel-*lowlatency ; do
if grub_file_is_not_garbage "$i" ; then list="$list $i" ; fi
done
list2=
for i in /boot/vmlinuz-*generic /vmlinuz-*generic /boot/kernel-*generic ; do
if grub_file_is_not_garbage "$i" ; then list2="$list2 $i" ; fi
done ;;
list=
for i in /boot/vmlinuz-*lowlatency /boot/vmlinux-*lowlatency /vmlinuz-*lowlatency /vmlinux-*lowlatency /boot/kernel-*lowlatency ; do
done
list2=
for i in /boot/vmlinuz-*generic /boot/vmlinux-*generic /vmlinuz-*generic /vmlinux-*generic /boot/kernel-*generic ; do
done ;;
esac
After changing it became:
case "x$machine" in
xi?86 | xx86_64)
list=
for i in /boot/vmlinuz-*lowlatency ; do
done
for i in /boot/vmlinuz-*generic ; do
done
for i in /boot/vmlinuz-*xanmod10-custom ; do
done ;;
list=
done
done
done ;;
esac
My ls -alh /boot and sudo update-grab2 commands show the next:
$ ls -alh /boot
total 275M
drwxr-xr-x 3 root root 4,0K feb 17 00:32 .
drwxr-xr-x 20 root root 4,0K feb 13 09:55 ..
-rw-r--r-- 1 root root 231K jan 17 15:59 config-5.3.0-29-generic
-rw-r--r-- 1 root root 231K jan 17 15:59 config-5.3.0-29-lowlatency
-rw-r--r-- 1 root root 138K feb 16 03:54 config-5.4.18-xanmod10-custom
-rw-r--r-- 1 root root 216K feb 15 19:56 config-5.5.0-4.1-liquorix-amd64
-rw-r--r-- 1 root root 237K feb 15 16:06 config-5.5.4-xanmod3
drwxr-xr-x 4 root root 4,0K feb 17 00:28 grub
lrwxrwxrwx 1 root root 35 feb 16 09:06 initrd.img -> initrd.img-5.5.0-4.1-liquorix-amd64
-rw-r--r-- 1 root root 46M feb 13 21:37 initrd.img-5.3.0-29-generic
-rw-r--r-- 1 root root 46M feb 14 00:01 initrd.img-5.3.0-29-lowlatency
-rw-r--r-- 1 root root 12M feb 16 08:36 initrd.img-5.4.18-xanmod10-custom
-rw-r--r-- 1 root root 53M feb 16 09:07 initrd.img-5.5.0-4.1-liquorix-amd64
-rw-r--r-- 1 root root 52M feb 17 00:32 initrd.img-5.5.4-xanmod3
lrwxrwxrwx 1 root root 30 feb 16 09:06 initrd.img.old -> initrd.img-5.3.0-29-lowlatency
-rw-r--r-- 1 root root 179K jan 28 2016 memtest86+.bin
-rw-r--r-- 1 root root 181K jan 28 2016 memtest86+.elf
-rw-r--r-- 1 root root 181K jan 28 2016 memtest86+_multiboot.bin
-rw------- 1 root root 4,5M jan 17 15:59 System.map-5.3.0-29-generic
-rw------- 1 root root 4,5M jan 17 15:59 System.map-5.3.0-29-lowlatency
-rw-r--r-- 1 root root 4,2M feb 16 03:54 System.map-5.4.18-xanmod10-custom
-rw-r--r-- 1 root root 3,9M feb 15 19:56 System.map-5.5.0-4.1-liquorix-amd64
-rw-r--r-- 1 root root 5,1M feb 15 16:06 System.map-5.5.4-xanmod3
lrwxrwxrwx 1 root root 32 feb 16 09:06 vmlinuz -> vmlinuz-5.5.0-4.1-liquorix-amd64
-rw------- 1 root root 11M jan 17 16:35 vmlinuz-5.3.0-29-generic
-rw------- 1 root root 11M jan 17 16:35 vmlinuz-5.3.0-29-lowlatency
-rw-r--r-- 1 root root 6,6M feb 16 03:54 vmlinuz-5.4.18-xanmod10-custom
-rw-r--r-- 1 root root 8,9M feb 15 19:56 vmlinuz-5.5.0-4.1-liquorix-amd64
-rw-r--r-- 1 root root 7,2M feb 15 16:06 vmlinuz-5.5.4-xanmod3
lrwxrwxrwx 1 root root 27 feb 16 09:06 vmlinuz.old -> vmlinuz-5.3.0-29-lowlatency
$ sudo update-grub2
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.4.18-xanmod10-custom
Found initrd image: /boot/initrd.img-5.4.18-xanmod10-custom
Found linux image: /boot/vmlinuz-5.3.0-29-lowlatency
Found initrd image: /boot/initrd.img-5.3.0-29-lowlatency
Found linux image: /boot/vmlinuz-5.3.0-29-generic
Found initrd image: /boot/initrd.img-5.3.0-29-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
done
I removed excessive code not needed in my case, then copy-pasted a pair of for loops for lowlatency kernel and changed lowlatency to xanmod10-custom in it.
$ ls -alh /etc/grub.d/
total 136K
drwxr-xr-x 2 root root 4,0K feb 17 00:28 .
drwxr-xr-x 141 root root 12K feb 17 00:31 ..
-rwxr-xr-x 1 root root 11K feb 11 16:57 00_header
-rwxr-xr-x 1 root root 6,2K feb 11 16:57 05_debian_theme
-rwxr-xr-x 1 root root 16K feb 17 00:28 08_xanmod_custom
-rwxr-xr-x 1 root root 37K feb 11 16:57 10_linux_zfs
-rwxr-xr-x 1 root root 13K feb 11 16:57 20_linux_xen
-rwxr-xr-x 1 root root 2,0K feb 28 2016 20_memtest86+
-rwxr-xr-x 1 root root 12K feb 11 16:57 30_os-prober
-rwxr-xr-x 1 root root 1,4K feb 11 16:57 30_uefi-firmware
-rwxr-xr-x 1 root root 214 feb 11 16:57 40_custom
