I have a problem with Bluetooth on my Laptop. It seems to get stuck on searching for devices.
I looked through AskUbuntu already and found a few great, detailed solutions, but I don't know what firmware I need. Here are the outputs of commands I found online:
dmesg | grep -i bluetooth
[ 20.793040] Bluetooth: Core ver 2.22
[ 20.793074] Bluetooth: HCI device and connection manager initialized
[ 20.793081] Bluetooth: HCI socket layer initialized
[ 20.793085] Bluetooth: L2CAP socket layer initialized
[ 20.793095] Bluetooth: SCO socket layer initialized
[ 21.153861] Bluetooth: hci0: BCM: chip id 70
[ 21.154856] Bluetooth: hci0: BCM: features 0x06
[ 21.170837] Bluetooth: hci0: BCM43142A
[ 21.170844] Bluetooth: hci0: BCM (001.001.011) build 0000
[ 21.449876] bluetooth hci0: Direct firmware load for brcm/BCM.hcd failed with error -2
[ 21.449883] Bluetooth: hci0: BCM: Patch brcm/BCM.hcd not found
[ 24.056776] Bluetooth: hci0: command 0x1003 tx timeout
[ 24.058451] Bluetooth: hci0: unexpected event for opcode 0x1003
[ 5417.077645] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5417.077649] Bluetooth: BNEP filters: protocol multicast
[ 5417.077657] Bluetooth: BNEP socket layer initialized
[ 5513.623521] Bluetooth: RFCOMM TTY layer initialized
[ 5513.623532] Bluetooth: RFCOMM socket layer initialized
[ 5513.623543] Bluetooth: RFCOMM ver 1.11
[ 5538.321869] Bluetooth: hci0: command 0x1003 tx timeout
[ 5538.323516] Bluetooth: hci0: unexpected event for opcode 0x1003
[ 5734.376654] Bluetooth: hci0: urb 0000000094ad7f77 failed to resubmit (2)
[ 5739.698606] Bluetooth: hci0: BCM: chip id 70
[ 5739.699750] Bluetooth: hci0: BCM: features 0x06
[ 5739.715784] Bluetooth: hci0: patryk-Lenovo-G50-45
[ 5739.715798] Bluetooth: hci0: BCM (001.001.011) build 0000
[ 5739.715927] bluetooth hci0: Direct firmware load for brcm/BCM.hcd failed with error -2
[ 5739.715934] Bluetooth: hci0: BCM: Patch brcm/BCM.hcd not found
lsusb
Bus 002 Device 004: ID 105b:e065 Foxconn International, Inc. BCM43142A0 Bluetooth module
Bus 002 Device 003: ID 5986:0652 Acer, Inc
Bus 002 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
As you can see it tries to load BCM.hcd firmware and while I found this repository on Github: https://github.com/winterheart/broadcom-bt-firmware I don't know which firmware I should use.
