I have a NAS running Ubuntu Server 18.04 with minidlna. Minidlna has been unmaintained for a long time and now it kind of sucks. I read that 19.10 has an integrated dlna server, but I couldn't find any instructions on how to use it on Ubuntu Server without a GUI. I'm willing to upgrade to a non-LTS version if it gives me a better DLNA experience, but I'd like now if and how it's possible to use that feature without a GUI.
Asked
Active
Viewed 9,270 times
The DLNA server in question is Rygel, which is part of Gnome, which Ubuntu uses. Normally that might suggest you might need Gnome (and a graphical server), but you can —as far as I can see— run this headless, from a command line.
sudo apt install rygel # double-check what this is going to install before saying yes!
Then edit /etc/rygel.conf or ~/.config/rygel.conf based on man rygel.conf to set your settings. The main one you'll want is the uris setting, to define where your media is stored.
uris=/data/my-films;/data/tv-recordings
Then just run rygel. You'd probably test it at this point before adding a systemd service to keep it alive.
Oli
- 299,380
